Editor problems
Using WP Version 6.4.2 and latest theme Newspaper Version 6.4.2.
I have this weird editor divided in 2.
https://i.imgur.com/61ip17o.png
The latest version of the theme is 12.6.3
If you are using the Gutenberg editor, then there will be no sidebar in the editor, this will look like this -> https://i.imgur.com/F6PUBhU.png
If you are using some classic editor plugin, then the sidebar can be removed only from the files, for this, you need to go in -> wp-content/themes/Newspaper/editor-style.css and comment these lines of CSS -> https://imgur.com/EpWJhGZ
Hope this will help you!
Hello.
Thanks a lot for the answer. I can’t manage to modify the code with child theme, not to modify the core theme files.
May be put in mind to make specific classes for Guttenberg and not override classic editor mce ? Thanks.
  • This reply was modified 2 years by codrutb.
We recommend using the Gutenberg editor, which is the official WordPress editor.
