Hello, i ve a problem with the embed post.
Go to the link pls -> https://www.mysocialweb.it/guida-my-social-web/
Hello gorghi92,
I have inspected your website and I saw through your source page that you want a lot of issues as you can see here -> https://www.screencast.com/t/d2On5fApL Also, I saw that you are using a lot of untested plugins which can interact with the theme core files and cause a lot of unknown errors as you can see here -> https://www.screencast.com/t/Fzl5AhqSi If you want to achieve best theme results, you should use only the required and tested plugins with the theme. Remove all of them, clear all the caches and check the results. Should works as expected. Also, if the problem is still there, try to make a new clean install from scratch via FTP to another subdomain and check the results.
Hope this helps!
Thank you very much. I solved, there was disabled the function on WpRocket of embeded. 😀
I ve another question, sorry…
Since i had install the theme i ve a problem with google+ sharing. If i copy the link on google+ the post appear without the title. How can i do?
the website is: https://www.mysocialweb.it
i ve the problem with the title when i paste the link of an article on google+ .
See the screenshot: https://www.screencast.com/t/2RWdVdaRhVO2
Thank you
This reply was modified 8 years by
gorghi92.
I guess that you are referring to the Google+ when you share the post on that social network, right? If you will check our demo preview, you will see that thing work as expected as you can see here -> https://www.screencast.com/t/rJiYzmXS2 Please notice that the theme does not have any control over it. So, if you want to manage this section, you should install the plugin, Seo Yoast. I have inspected your website and I saw that you using such an untested plugins which can interact with the theme core files and cause a lot of unknown issues. For example, I have checked your social media section from your website and I saw these buttons which do not come from our theme functionality -> https://www.screencast.com/t/PQnysoVhrXA Most likely, these come from plugins which are not tested with our theme and which can break it.
I already use Yoast Seo. I don’t think that the problem is caused by the plugins because before the installation of the “Newspaper” theme i hadn’t it. There are all snippets on the article page. If i paste the link of the article on Facebook, Twitter or Linkedin, the title appear; while on google+ appear only the author.
