Enable Features for Big Grid and Flex Block
Can you please watch this short video and teach me how to enable these options?
If you just tell me Dashboard > TagDiv Composer > Flex Block > General, Layout, Style, or CSS > Setting > Selection > etc….
I should be able to fix.
First, for category post, if you have more categories on that post, then you can set which category you want to be displayed on the block, also, to set the primary category on the post, you need to set in Posts, not Theme Panel => https://www.screencast.com/t/AlONv6eOfpLD edit a post and go to the bottom of post content and then you see the settings => https://www.screencast.com/t/CC3mVxxh and after you set the primary category, edit with tagDiv Composer, select the block and search after category tag => https://www.screencast.com/t/InnUjOrN9, also please make sure is set to show on each module => https://www.screencast.com/t/IWvWZByH -> https://www.screencast.com/t/xGqf1cB3 -> https://www.screencast.com/t/bMRXe6vDo
For navigation on the block, you can add it from a tab called “Filter” and select which ajax categories dropdown you want => https://www.screencast.com/t/pLPP1XYNH1
Hope this helps you!
Sorry, but the instructions you sent did not solve my issue. Please see below.
Filter by Categories gives me All, Business, Crime, Development, Eat & Drink, More (dropdown)
Filter by Taxonimies gives me only the selection “All”
Filter by ID Tags gives me All, lebanon, tn, tennessee, mt. juliet, obituaries, events, more (not sure why these are not capitalized.
So, none of the above settings gives me the below.
Element Used: Flex Block 3
Ajax Categories has been enabled.
I need it to display the below.
Parent Category: Latest News
Alax Tabs: Eat & Drink, Entertainment, Events, Health & Fitness, Kids & Family, Things to Do, Travel.
How do I get these specific categories to show up in those tabs?
As you can see in screenshot below it does not give me these options to select from.
Ajax Category Tabs
Hello !
That can be done by filtering the categories after their id as you can see here: https://www.screencast.com/t/CWZtvzGbHo
