Hello, I want the possibility for a custom post type to have the “Post settings” enabled.
More precisely this:
post settings
I need it because I want to associate a post template to a specific cpt, with all the settings related to it.
Thank you
Hello okgo87,
Unfortunately, the Post settings are not available for Custom Post Type, sorry! You should make some additional customizations through the code and we cannot provide custom services at the moment, sorry! If you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you!
Hello okgo87,
Unfortunately, please keep in mind that you cannot make to link the post settings to your custom post type because are just two different taxonomies and the functionality of post settings will not work for your custom post type. A quick solution in this regard would be to change the default post template by your desired and then you will have the post settings. It is just a suggestion.
If you want to display more levels in our theme and if you are not aware of the steps which are needed to take in this regard, please consider hiring a freelancer/developer to help you because we cannot provide custom work at the moment, sorry!
