I had edited my homepage and add the social media counter using TD composer before (it worked well). but after that, i want to do some editings on my homepage, only to find the endless loading of TD composer… it wasn’t showing me anything like before, only the spinning load page which seems infinitive… can you help me about it?
Hello Danu R,
Please check the system status parameters to be increased according to the following documentation here -> https://forum.tagdiv.com/system-status-parameters-guide/
Hello Danu R,
Please remove all of the untested plugins if you are using something like this, clear all the caches and check the results. If the problem is still there, I suggest you make a new clean install from scratch via FTP way, clear all the caches and check the results. Also, if the problem is still there, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further investigate it closer your setup page. Provide there the link to this topic so we can quickly identify you.
