Please check the console and see if there is an error. With right-click -> inspect -> console -> select the error in the tab network -> preview, you can see the cause.
Please make sure that you don’t have mixed content errors; you can check the console. You have to use an SSL plugin to fix it and then try to activate it again -> https://www.hostinger.com/tutorials/fix-mixed-content-wordpress/ -> https://wordpress.org/plugins/really-simple-ssl/
