ERR_TOO_MANY_REDIRECTS how to fix?
Help, i cant acces my web
how to fix it?
You can try these options (note, theme does not create redirects)
Check your htaccess file and remove any redirects there, as first option.
Remove child theme folder; consider not using one.
Second, if you activated a bad plugin; rename your plugin folder to xplugins via FTP; this will force disable all plugins. Or, remove any ‘redirection’ plugin from the plugins folder if you recently activated one. Or, try removing Yoast SEO if you setup a bad setting for that.
If you still cannot access; delete all themes in wp-content/themes except twenty-sixteen which will force WP to ‘fall back’ to that version.
if i delete all theme (include newsmag theme) and i install new version of newsmag again .
it will not delete all my web data (photo, post, etc)?
HI
If you delete theme’s folder from your WordPress install your date won’t be affected but any customization made in theme’s files will be lost. As a security measure make sure you do a full backup to your current wp-install before making any changes: https://codex.wordpress.org/WordPress_Backups
FYI
reason to delete extra themes and rename plugins folder is to solve not being able to login.
The “transient” settings and “dbase” settings for theme will be retained.
BUT: good to “save/export” any customizations you’ve done in theme panel to a text file.
I forgot to do that recently and after server RAID crash… I went “waaaah”! … actually I cursed, but that isn’t polite to print here 😉
