ERROR Clicking on old posts redirects not to the post, but to home page
The problem is when you click any old post that is under ‘load more’ ‘Infinite Load’, it does not redirect to the post, but to the Home page. How to fix this?
this is my web: http://www.hands-on.com.vn/news
  • This reply was modified 8 years by Goyo.
It seems that all the block pagination is doing the same. Even if you use the ajax filter on blocks, the posts that are filtered are redirecting to the homepage. That is not how the theme works by default.
I suggest that you deactivate all plugins except theme plugins, clear all caching next. Temporarily remove theme files modifications and code added in the theme panel. Also check your htaccess file for redirects.
Analyzing one of the posts links, on your website, this redirect chain is displayed
– https://www.screencast.com/t/Aynq9LJh
The theme will not redirect anything, so either this has been done in the htaccess, by a plugin or other redirect tools.
