ERROR -> Problem editing my post pages with TagDiv Composer
when I try to enter TagDiv Composer to edit an element, an error appears on the screen: “Errors at columns elements: 21(models) : 20(dom). The model does not match the content Current state has an issue. You could try involved an UNDO operation (CTRL+Z / CTRL+SHIFT+Z)” and I can’t perform any operations, I can’t edit code and nothing.
I need some help, I don’t know how to mess with advanced code settings. I’m leaving the screenshot links attached to check the problem:
1- https://snipboard.io/8CUoPA.jpg
2- https://snipboard.io/N4KVMT.jpg
Hello Felipe!
This issue with the error from Composer has also been discussed here: https://forum.tagdiv.com/topic/errors-at-columns-elements-5/
Please make sure you did all the steps which I mentioned here: https://forum.tagdiv.com/topic/errors-at-columns-1models-0dom-the-model-does-not-match-the-content-curr/
Hope that helps you!
