Also, be sure you upload the theme which is just the theme files, and not the entire “everything” zip archive which has the theme AND the documentation, as this won’t work. Always safer to upload via FTP if you can. If using the WP panel and zip archive, make sure it’s just the theme only zip (on Themeforest you have choice of two files, just the theme, or everything…. if you upload the everything zip, it will give you server error).
Hope that helped! 🙂
