Error with custom fonts
I uploaded a custom font to use on the site, but it is not displaying correctly (https://eshoje.com.br/homepage-job-hunt-pro/)
I did a local test and it works without problem. https://i.imgur.com/GNMplkG.png
How do I resolve this?
If I correctly understand you’ll like to use a local font, right? for this you’ll need to set it in the theme panel, this can be done using our guide – https://forum.tagdiv.com/font-customization/ after the font is set in the theme panel, you’ll need to assign it on elements you want to use it.
According to the screenshots everything is correctly set in theme panel and composer, but on block on front I do not see that the font to be set – https://i.imgur.com/GdtbNb3.png do you use some cache plugin? If yes, please do a test whiteout it.
Let us know the results!
We solved the problem by loading the font again, changing the name and changing it in all blocks of the templates
