Even subscribers can view and click on “Edit template” and “Edit post”
I have noticed that even subscribers can view and click on “Edit template” and “Edit post”. Yes when clicked on, these buttons lead to nowhere, but for a subscriber, this shouldn’t be visible.
I have only tagdiv plugins, litespeed cache and acf plugin installed.
Yes I have cleared cache and everything but the problem persists.
The problem only exists when the user is a subscriber. So I have switched all the users to contributors and problem solved.
Thank you
There is a problem with the plugin you use. You should allow only tagdiv plugins without LiteSpeed and acf and check afterward.
