i would like a simple events plugin but i the one i tried isnt compatible with speed booster plugin,
Any recommendations?
PS: i just really need some simple events plugin, and one or 2 widgets included to show on sidebar.
thx
Thx.
But i think i need use speed booster, due to pages will load faster.
The speed booster was tested only with these plugins – http://screencast.com/t/hcjLnOqh4i2 and if you use other plugins it will be automatically disabled. A lot of people install the plugin without knowing what it does and after that they add many plugins and some of the them are not written fine so the developer took this decision.
If you want to always enable speed booster, delete this code from speed booster file: http://screencast.com/t/RZLIOPUNdqh
