Is it possible to exclude current post being read from a block in sidebar.
Say I had block1 in sidebar and I want the most popular in there. The block shouldn’t show the current post in it.
If that’s not possible what would be the best way to do it in td_api_plugin creating a block ?
This is a complex task which require lots of customizations in theme’s files and I can’t provide a solution now. You can find more details about td_api_plugin usage in our documentation: https://forum.tagdiv.com/practical-example-how-to-add-a-new-block-and-module/
Please consider that this task require good coding skills and if you can’t do it yourself my advice is to find someone to help you or hire a freelancer from sites like http://studio.envato.com/ to do it for you.
