on my homepage I have three main blocks of posts:
block A – main flex block 4 which shows the latest published post, regardless of category/tag/author etc.
block B – flex block 4, which shows 3 latest posts from few selected categories (e.g. X, Y) that are usually more articles written in more depth
block C – flex block 5, which lists 3 latest posts from a single category (e.g. Z), which are usually basic news posts
There’s no offset in any of them, but I encounter a repeating problem. Because block A is displaying whatever was posted lately, that same post will appear in either B or C blocks, depending on the latest posts’ category.
Meaning if I post something in category X, it appears under blocks A and B; if I post something in category Z, it will appear in blocks A and C.
I can’t use offset in B or C blocks as one of them will wrongly remove a post that’s not displayed in A, i.e. when latest post is category X, block C will wrongly offset one post from category Z which then isn’t displayed anywhere.
What do you suggest I do to add some form of logical non-duplication, ideally doable directly through Cloud templates which will ensure it not breaking in the future?
Using latest Newspaper and WP versions.
A solution could be to use the unique article option, follow this guide: https://forum.tagdiv.com/unique-articles/
This option automatically removes duplicate posts from the page.
