Is it possible to exclude unique posts from appearing in popular post view?
Background: I got some very old posts which seem to be hit by robots a lot. So this 3 non-relevant posts appear in popular posts all the time. I would like to exclude those entries bei id.
Unfortunately the theme doesn’t have an post by ID filter. You can use the tag filter to control the posts that appear in the popular posts block and bulk edit all posts and add the tag to all post that you want to show in that block then in block editing panel add that tag to filter posts by it so only the posts that have that tag set will be displayed.
Hope this helps!
