Exclude Previous Posts? (yes/no) / Exclude These Posts Later? (yes/no)
Hello, I have a question that is simple, not sure if it has been discussed in other forums
In your theme Newspaper, in using Visual Composer blocks with different shapes, I want to achieve this result as follow:
I have a category or multiple categories of posts to flow from one block (i.e. block 19) to and through multiple blocks to another (i.e. Block18; block 16, etc…) without showing the same (repeating)number of post/posts in a block into another one/ones (of the same category or other categories) on the same page.
Example: category All =20 posts or Category A; B; C; D with their amount of posts
Block 19 order Desc or random – category all or single, posts to show 6, the overflow of posts into another block with same settings.
This to avoid to show the same post in another block beside separating blocks to show single or multiple categories
Please help achieve this with your theme and visual composer
Thanks Sal
Please read this guide:https://forum.tagdiv.com/block-settings-guide/
The ‘offset’ setting is the one you are looking for
