I have added a few custom fields to the post title, so that for instance locations can be selected from a dropdown list but still show up in the title.
However, now the permalink for the post now only relates to the the post title.
For instance: “Paul Weller 5 oktober 2018 Depot, Leuven” is now only a link in the “Paul Weller” bit of the text, where we would like to have the complete thing as a link.
Any thoughts on where and how I can change this ?
This is currently the code:
<div class="post-title">
<?php get_the_title( $id );?>
<?php echo $this->get_title($title_length);?><h3 class="entry-title td-module-title">
<?php $datum = get_field( "datum" , $this->post->ID ); //etc...?>
<?php if ( $datum ) : ?><span class="cemetadate"><?php echo $datum ; ?></span><?php endif; ?>
<?php $concertlocatie = get_field( "concertlocatie" , $this->post->ID ); //etc...?>
<?php if ( $concertlocatie ) : ?><span class="cemetacelocation"><?php echo $concertlocatie['0']; ?></span><?php endif; ?></h3>
</div>
The permalink would display the post title if that is how it is set in WordPress settings. I found some topics about including custom fields in the permalink structure, maybe they are useful to you
– https://wordpress.stackexchange.com/questions/294011/change-permalinks-with-acf-values
– https://permalinkmanager.pro/2017/07/10/easily-use-custom-fields-inside-wordpress-permalinks/
– https://support.advancedcustomfields.com/forums/topic/add-acf-field-to-permalink/
– https://stackoverflow.com/questions/33651786/how-to-use-custom-acf-fields-in-wordpress-permalink
– https://wpquestions.com/Add_custom_field_to_permalink_URL/3014
