Hi, i have by blog http://www.bulletintech.com the problem i am facing is that the smart sidebar is not working properly. Kindly let me know
You have lots of js errors in your console http://screencast.com/t/k44YbThyHXfl
Please disable all plugins except visual composer, clear cache and reset cdn files if you use it. This should eliminate any plugin conflicts. Then check your sidebars again.
Let us know how it goes.
