Facebook comment count in little box and top recent posts by Facebook comment
Hi there
I would like to show the Facebook comment count on the little box that appears on article lists instead of the WordPress one.
Also, I would like to show top posts by recent Facebook comment (say last 30 days) to show popular posts with Facebook comments.
Okay so in td_module.php i have done this
But it still shows zero?
  • This reply was modified 11 years by vzey.
To achieve that functionality it’s need to understand the way Facebook plugin count the comments, then add that value inside the get_comments() function. This is a complex task and I cannot provide a quick solution now. If you need this implementation my advice is to look for a freelancer from sites like http://studio.envato.com/ to do it for you as we cannot offer any type of custom work at the moment.
