Facebook comments and embeded facebook posts – text color problem
I’m having a problem with my facebook comments text, although I’m not sure where exatcly is the problem.
Everything was ok untill few days ago when we noticed that text color of fb embeded posts and fb comments is ‘too dark’ (set on #1d2129). I configured fb comments plugin so it uses light theme, also tried using dark theme, nothing helps. screen here http://www.screencast.com/t/b18JixPHywH1
Please could you provide some help on this matter or at least give me some guidence.
Mladen
Hello mabaz,
You can use a bit of CSS code to change this color for your comments. As a hint, you will have to use your Inspecter and try to target the class for these and change the color. For more information about how you can use your inspector, please check here -> https://forum.tagdiv.com/create-custom-code-using-the-browsers-inspector/
Also, if you need more assistance in this regard, please provide your website so I can provide a more accurate response.
Thank for your understanding!
Hello Catalin,
thanks for quick response.
I’ve tried changing text color using css, actually I use inspector in chrome to find proper css selector that could be used for changing the mentioned fb post and fb comments text color. So far I haven’t been so successful.
Here’s link of post on my page: http://www.novitravnik.ba/dirljiva-poruka-iz-novog-travnika-lokalne-kabadahije-skloniti-ceste/
I’m kindly asking if you could provide some specific suggestion on this.
Mladen
Hello mabaz,
I have inspected your FB section and I noticed that this type of plugin uses an iframe to bring the comments from Facebook and you cannot change or modify the iframe elements, sorry! Please try to find some plugins with this functionality which allows you to find that color of these which come by default. Another alternative for you woould be to change the demo or the background with a lighter one.
Thank you Catalin!
Mladen
