Fading Problem
Hi. When making changes to elements with td composer, it should fade and then ‘unfade’ with the new changes. However, I have noticed for some time now that sometimes it fades when applying a new change and then freezes, and I cannot make new changes unless I click save on tdcomposer and refresh the page (see screenshot http://prntscr.com/l6f6ys). Would you know what the problem could be? cheers!
Check if there are any errors in the browser inspector console when this happens, then let us know by some screenshots if possible, and mention what you were doing or editing at the time.
It occurs sometimes not every time. I will note it next time it happens. In this instance, I was changing fonts for the date template 9 when it occurred. But I have seen it occur a few times in the past two months.
