Feature images not displaying for posts
We’re using your wordpress theme. The feature images are not displaying on the homepage.
See: http://www.centralmcsa.org/
See posts under ” Latest blog posts” not displaying the images on homepage
Can you please tell how to fix this?
This error usually comes from a JavaScript error. These errors usually come from a plugin conflict or JavaScript minification. The lazyload animation causes the images to disappear as it breaks on a js error. You can either disable the lazyload animation from the theme panel or try to find the conflicting plugin that causes the error. If you just disable the lazyload please check other parts of the website as they can be affected as well by the error.
