Feature to load single posts infinity
hi, for a few weeks i asked you on themeforest if there are any plans to implement a infintiy scrolling on single posts like: http://thevoux.fuelthemes.net/blog/elevate-your-listening-with-these-top-notch-sound-systems/
One of you said that this feature is plannend.
Question:
1.Any release date for this Feature?
2. Any topic where new features are discussed?
thx
Hello newtag,
1)In a future update, it is possible but we cannot say for sure if it will get done in the next update because we have a big list of fixes, improvements, and suggestions to implement. It’s hard to filter them and select which one gets implemented now and which one gets postponed. The developers decide if it gets done or not, though. Until we can do it, you can use a plugin.
2)You can try to check in our forum by the infinite scroll and will find some threads with this subject discussed. As example, you can check this -> https://forum.tagdiv.com/topic/implement-infinite-scroll-on-single-posts/
hi, thx for the info. But the other discussion is not helpfull,
I found a plugin that works perfect on other themes –> https://wordpress.org/plugins/infinite-transporter/faq/
But i cant get it work on the single page (i already included the code in the functions php)
The Plugin works nearly with alle free themes on the wp repository but not with the newspaper theme 🙁
I can change the templates if you tell me wich changes i should make. I tried to include id=”content” – but it does not work. It would be awesome if you can help me out. please install the plugin and check it – it takes only 5 minutes 🙂 This is a must have for me – this was the reason why i asked before i bought the theme. Thank you so much
best
  • This reply was modified 10 years by newtag.
Hello newtag,
In principle, you need to do a custom template that supports this kind of pagination with this plugin because our templates do not support this. Unfortunately, we do not have a solution for this, but we will try to implement this feature of our next update. I have installed this plugin on my side and please notice that is not a simple task to make it work fine with the theme because it is necessary to do some additional customizations through the code until it runs correctly and these involve more customizations, sorry!
Sorry for the inconvenience!
Ok – thx.
Please implement this in the next update. In this case i will buy a second theme to support you.
best
