I have two problems and I think, both of them is related with each other.
1- Sliders are not working regularly. Slider’s timing doesn’t operate and headers of each post overlapped. It did suddenly, I don’t know why it was. Also, you can see the problem, the half of image is applied effect. But, It also prevents to click to post. You can see the problem here in first slider: https://www.gastesehir.com/yazarlar and second slider similarly in homepage.
2- Now, in any posts, there is no featured image in template style 7. What can be its reason? First, some images cropped half yesterday, today I cannnot see any image in any posts. You can see the sample from here: https://www.gastesehir.com/haber/ressam-bozcali-sergisi-icin-taha-toros-arsivi/
I read many articles in Newspaper forum and tried some css codes. Also, I looked to something in caches and Lazyload fade effects. But, I can’t succeed.
If you clarify what my problem is I’ll be really glad.
Thanks in advance,
Hello gastesehir,
I’ve checked your website and I saw your problem. Also, I have checked your console and I noticed that you have a lot of JavaScript errors, like this -> http://screencast.com/t/ueK1VHa7S
These kinds of errors come from plugins. Please try to disable all the active plugins, except Visual Composer, clear all your caches, purge CDN fine if you used and install only the plugins that come bundled with our theme and rule out a plugin conflict. After this changes, please check the website and if your problem is still there, please let us know.
Hope this helps!
Thank you for the message!
Hello Catalin,
I applied your instructions. First, plugins are disabled. Then, I cleared all caches and did required things for CDN.
But, when I checked again website, the images in posts and corrupted sliders are same. There is no result.
Why do it occur?
Thanks,
Hello again,
I succeed it how to disable all plugins again and the problem is solved. Thanks,
I did the same, deactivated all the plugins and did all of the steps. But still I can’t see the slider on my website. Please help me out.
Regards
Hello ismailblogger,
Please ensure that you have disabled all the active plugins, except Visual Composer, clear all caches and install only the plugins that come bundled with our theme…this kind of problem seems to come from plugins conflict and, therefore it is very important to follow these steps to rule out a conflict plugins. If your problem is still there, after this changes, please provide your URL website so I can further inspect the issue.
