Featured Images are not visible on phones, webmaster tools and other tools
My featured images are not visible at all on some of the phones and they’re also not visible on online SEO tools etc… I can see pics on my PC so I don’t know what’s going on.
http://prntscr.com/kk5y73
link for the page is https://bjj-world.com
  • This topic was modified 8 years by Colleric.
None of your featured images seem to be displaying but they are loading. But found this:
https://themeforest.net/item/newspaper/5489609/comments?page=318
Look to this style – if you change the opacity value your images all show up
body.td-animation-stack-type0 .td-animation-stack .entry-thumb, body.td-animation-stack-type0 .post img
