Hi…
We just bought another license for this wonderful theme, our 3rd!
For some reason, the featured images are not showing up
on the home page, and category pages on desktop.
They are fine on mobile and on the actual post pages.
I am probably missing a setup in the theme panel, but I can’t find it. URL below.
Thanks for your help.
This could be a plugin conflict so please disable all plugins except visual composer, clear cache and reset cdn files if you use it. Please also check any custom code you might have added to the theme panel or the theme files. If you use a child theme, please switch to the main theme to make sure it does not affect the proper functionality of the theme.
Hi – I already did all that, as I have seen others in the forum with this issue.
Using zero plugins, standard theme out of the box, no modifications, no custom code, no child theme…
Just a stock install.
I have also turned off lazy load,
and still having problems with images not being pulled
into front page, and category page displays.
Please help… would a login to look help you?
Please contact us on our email address at contact@tagdiv.com and provide a link to your site and wp-admin (login information and admin rights) so we can login and investigate. Please also include a link to this topic so we can identify you.
