So a lot of features missing. Like the boxed layout or the mobile customize theme. Also i don’t have the top menu on the mobile version. The biggest problem is that in the 10.4 version youzify-buddypress plugins are destroying header and footer on their pages. its all white. see for your self: https://playsiders.com/members/
So i have multiple problems. Whats going on?
I can see your mobile menu is working well.
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
Also, make sure your WordPress and plugins are up to date(specially Standard Pack installed and active if you use default templates).
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache(also from your browser) and try again.
Let me know the results!
Hi. So i tried it. But nothing. The problem is with tagdiv composer. Something is happening there. The only problem that left to fix is the youzify plugin that is all white on header and footer. And also it shows 2 “td-icon-menu-up”. From mobile you can’t see a lot of difference. But from Desktop it is clear to see this.
For that issue please check this topic: https://forum.tagdiv.com/topic/header-error-with-youzify-and-buddypress/
