Features of two blocks together
I am facing a problem here.
I use Block 15 for my home page, but it does not show the date.
Now I tried Block 16, but it does not show the category tags.
My requirement is this, I need to show both date and category tag for such a block.
Is it possible some how?
-Josin
Hello josinc,
If you want to display the date for your Block 15, you should edit the td_module_mx4.php and add the following snippet of the code here -> https://www.screencast.com/t/SVukoRDOz
If you want to display the category tags for your Block 16, you should turn on the settings from Theme panel for module mx7 from here -> https://www.screencast.com/t/CbJKqSrI
The results can be seen here -> https://www.screencast.com/t/wYvwOWZvOU88
Thank you Catalin for the great support.
-Josin
Let me ask one more question.
How can I change the colour of category tags in homepage from black to some thing else?
-Joisn
Try the code below and place it in Theme panel->Custom CSS area.
.td-post-category {
background-color:red;
Thank you Edward!
It indeed worked except for Big Grids in home page.
Any suggestions?
-Josin
Don’t mind, I figured it out!
