Few Issues I Need to Troubleshoot
– Is is possible to change the header for the Instagram footer? I’d like it to say “Follow Me” vs. “Follow Us”
– When a new block of posts is loaded, it’s loaded on the next line & looks messy. Is it possible to have new posts load next to the last post?
– Sometimes, when the thumbs load for the post blocks, they’re not all the same size. How do I fix this?
– Is it possible to adjust the formatting of all posts at once? I want to add text padding to my old posts.
1. Please use the translation section of the theme panel.
2. Please change the limit here: to one that is divided by the number of posts on a single line. In most cases it is 3 so a number such as 9 or 12 is needed https://www.screencast.com/t/r9uUbEPDYq
3. please use this guide: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
4. It can be done with custom css but you ned to provide exact, specific details to how you want it so I can provide the proper code.
Hi there!
In response to #4, I’m looking for all my posts to have text padding (two indents). Does that help?
Thanks for the prompt reply!
Christina
Hello Cuddlepill,
#4 If you want a more accurate code in this case, please provide your website URL so I can take a closer look at it.
Hello Cuddlepill,
If you will check your post content you will see that you can adjust it via such a custom CSS code -> https://www.screencast.com/t/prgoMdqGq I do not what exactly you want to achieve but please notice that all of the additional change should have to be done from the code by yourself be cause we cannot provide custom work at the moment, sorry!
