Few layout and technical questions
Hi!
Thank you for such a work you have made 🙂
I have few questions before removing standard pack and I hope you can help me these answers.
1) Does the flex blocks automatically don’t show 0 comment count? In standard pack it was showing 0 comments.
2) Where can I edit that comment count to show next to title. https://prnt.sc/2640bs6
With old version I just edited td_module_mx17.php as example and put get_comments before get_title, then that position went better 🙂 (Old example what you gave me https://content.screencast.com/users/andrei_tagdiv/folders/Jing/media/29662ffe-5364-408a-8ff1-47f12aeff055/2017-06-16_0854.png
Somewhere here yes? – /td-composer/legacy/Newspaper/includes/modules
3) I’m using Co Authors Plus plugin for adding authors on post page. I researched and now you use Molongui (or something like that) authors plugin what will work without Standard Pack but for old articles and new ones I still need to use Co Authors Plus Plugin to keep author settings with these articles.
Right now I have changed in Standard Pack /td-standard-pack/Newspaper/loop-single.php
https://pastebin.com/FGr9cUD9
Can I use it after disabling Standard Pack too? What file should I edit 🙂
4) About Single post template. Can it be used as a old way too, where article writers can write without tagdiv composer editor and using simple standard post page template? Mostly it’s pretty okay, only similiar posts are missing at the bottom. I havent tested with premium content plugin yet 🙂 but I’m sure it works with that too.
Best regards
Rauno
1. The flex blocks will display the comment count, but this can be disable individually using the tagDiv Composer -> https://i.imgur.com/tBn23QC.png -> https://i.imgur.com/c6MpnlW.png
2. Yes, that is the path -> https://i.imgur.com/FPSDV1y.png -> https://i.imgur.com/6hSTPc8.png
3. We did not tested the Co Authors Plus plugin with cloud templates, so I do not know if this code will work. But if you use the default post template -> https://i.imgur.com/BHbk31Q.png then the code should apply on the files from -> wp-content/plugins/td-composer/legacy/Newspaper/loop-single.php
4. The single post templates allow you to edit the post layout/template using tagDiv Composer, now this was not possible with a standard templates. The posts will be made using the WordPress editor (classic or Gutenberg editor).
I hope this will help you!
