Hello !
As you can see here it works perfectly: https://www.screencast.com/t/MACKAKqDQ ;
Make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Hello Friend!
Soon after, having created the topic, I searched the entire forum for a solution, found some answers, saying that it was to disable all plugins, clear cache and disable even the child theme. Well, I did it all and nothing was resolved. Below is a print of what is happening to me.
https://drive.google.com/file/d/1LJBqSMCy2qNYygye4D6ABBajb6U6VAlG/view?usp=sharing
Importantly, only filters by category and multiple categories. Does not work filter by tags and especially the id post, which for me and my client is critical. Please help me.
This reply was modified 6 years by
aproposta.
Hello !
– admin url and credentials
– cPanel url and credentials
Our team will take a look !
Hello !
Friends, I found the filter problem not working in flex box 5 and I believe in others. After installing the romania news demo. It comes by default in Offset posts value 4, causing zero posts to return when filtering by post id. Next update, you may leave the value empty.
Thanks for everything
