Filter does not work
If you want to eliminate some posts from showing up, then filter does not work. It saying that if you add – to post number. example: -7270, then post with that ID should now show up, but it still does.
The problem appears with:
Big Grid 5
Post ID filter: when you add -7270
https://imgur.com/IP4iL36
https://mkuubis.ee/
I did a test and for me works well, so please make sure that id is the post id that you want to remove.
Also, please check if it’s not a plugin conflict.
ID is correct one and there are no plugin conflicts. The problem looks like it does not work with sort order: “popular (jetpack + stats module)”. And this is the only working usable popular posts option but when it works every other filters, it does not work with -filter.
  • This reply was modified 4 years by Edragon.
Hi Edragon, when you are using the Popular (jetpack + stats module required) then the rest of the filters will no longer apply, this is mentioned in our guides -> https://i.imgur.com/G31FGEO.png -> https://forum.tagdiv.com/flex-block-settings-guide/ (our theme can not overwrite the options from the jetpack).
