Final module images do not display
Hi, on my website, the final block module does not load the images properly. The module only loads properly once the page is refreshed. How do I fix this? (On my website at https://tabesuki.com/, this would be the “more food” section.) Thanks a lot for your help!
For me all the images in the page are loaded properly, from top to bottom
https://www.screencast.com/t/7rIoDnhe
There was no need to refresh the page or any problem. If you are experiencing issues with the images, try disabling the theme lazy-load or other lazy-load feature you have active (such as Jetpack lazy-load). Check if this has any effect.
