First installation ist not working correctly
Hi from Germany!
This is my first installation of Newspaper! I have much articles on it, but there are some problems:
Article is not displayed – just the headline!
On opened article, there is no admin-panel at the top!
Demo with or without articles: Default Pro (but on any other template there is the same problem!
Look at: https://in-und-um-schweinfurt.de/x/music/eminem-stronger-than-i-was/
  • This topic was modified 4 years by 2fly4.
Hello @2fly4!
Sometimes, the issue can be from a plugin conflict or a cache issue, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache (also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
Hi again!
Many thanks – found out one plugin, that does not work with you theme!
Another question: is it possible to insert any php? Did not found a element for this!
Best Regards
Thomas
Hello Thomas!
Unfortunately, there is no element which allows you to insert php code.
Hallo Bettina!
Pls add 😉
Hello Thomas!
We will take in consideration your query and I will add this feature on our improvement list.
Thank you for the request and proposal!
