How can that section be alined in the middle on mobile device?
Usually, with the default settings, this element on mobile should be like that: https://www.screencast.com/t/hbtGWja1w
Please check the default size from default settings, or try to add the element again.
Hello, I have it in default but nothing changes…
http://prntscr.com/130z7ax
http://prntscr.com/130ziek
http://prntscr.com/130zkqq
I also added the element again, but the same thing happened.
Please advice.
These are the default settings: https://www.screencast.com/t/WTcRJ9bbrzX
Please increase the image width and see the results.
