I NEED TO CHANGE THE LOOK OF BIG GRAD FROM THIS
TO LOOK LIKE THIS :
AND THANKS FOR YOU HELP 🙂
Unfortunately the big grid you are pointing comes from the Newsmag theme. You can chose a different big grid for your homepage. Here you can try them out and there styles: http://demo.tagdiv.com/newspaper/big-grid-1/
As an alternative you can use the big grid slide block which resembles the one ion newsmag on the mobile version: http://demo.tagdiv.com/newspaper/big-grid-slide/ (it needs to be set to at least 8 posts)
You can force the slide to display like the one on newsmag but it is no easy task. You can follow this topic if you want to tackle this challenge: https://forum.tagdiv.com/topic/big-grid-on-the-mobile/
