Fix The Grid Problem!!
I’ve just updated and downgraded in a second. The Big Grids doesn’t work anymore. Please fix it asap.
Tks
More specifics?
Version of theme, version of VC plugin?
PHP version? WordPress version ?
After the update big grids only work on full width rows. Now appears the error message.
What does the error message say?
Are you running old version of PHP (5.2 ?) – you should have 5.6 or later.
Are you running WP 4.7.3 — older version should *not* be used.
What version of Visual Composer? Did you update that with the theme?
I have the same problem in my website. Im running php 5.6
“Big grid 4 Please move this shortcode on a full row in order for it to work.”
So, have you moved the item to a full row to get it to work?
Is work in full row, but only in full row after this update, why? bug? fix?
This is no bug. It is a simple check we added to prevent the use of the big grids on 2 columns.
The big grids were designed to work on 3 columns. They were never intended to be used on 2 columns.
Here is another topic with an explanation and a solution if you still prefer to use them on 2 columns:
https://forum.tagdiv.com/topic/bad-update/
It’s rather shameful that I have to be editing the code to solve something that work well.
If it ain’t broke, don’t fix it!!!
It was a really bad update. You messed it up this time.
