Fixing Block Offset in Homepage
Hello! I’m using your excellent Travel template in my site, http://www.southamerica-tours.net. I wanted to set a customized background image for the homepage, so I configured it in “Row Settings > Image”, as you can see in the blog. However, the image block has a little offset, moving a few pixels downward.
I’d like to eliminate this little gap between the header and the background image, would you please help me out with this issue, if there’s any option to configure or css style to edit? Thank you and best regards!
Hello jacobicho,
Please try the code below and add it in Theme panel->Custom CSS area.
The code is ->
.td-main-page-wrap {
padding-top: 27px;
The result you should see here -> http://screencast.com/t/tdr9TnpS4
Thank you for the message!
Worked perfectly! As always, thanks for your prompt, useful response. Best regards!
I tried the code you said and still unsuccessful. Theme Panel>Custom HTML is where it goes?
I have a white gap between my header and top image on homepage when using “Newspaper – Travel Guides”.
That code has to be entered in Theme panel-Custom CSS section here
– https://www.screencast.com/t/6oWfVjuGmUG
If you have a different problem, please provide a link to your website so we can inspect it, and give you a more accurate solution.
