In these elements, is it possible to display WooCommerce products as well, or do they only show the site posts?
Yes, the Flex block can display the products – https://i.imgur.com/0UO3u8L.png, but it will show them as articles — only the image and title, without the price. For WooCommerce products, it’s better to use the Woo Product Block element https://i.imgur.com/D3BK5az.png, as it includes the price along with the product details.
You can create the layout you want using the layout tab – https://i.imgur.com/hfcwcxL.png
In case you are referring to the fact that there is only one lock to use for Woo products, then yes, it is only one.
