Hi!
About Newspaper demo Gadgets PRO, is there the possibility on Flex Block 1, to have the same block’s height, with author alignment and “READ” to the bottom edge?
This can be done only if you set an excerpt/length of words or letters for posts title and content https://i.imgur.com/a53B2U5.png -> https://i.imgur.com/4LWvCNt.png
Calin, unfortunately, is a solution that does not suit my needs because then the phase shift comes with the title, when it is too short and remains on a line for example, and when it is long and is truncated on the fourth line.
You can play with something similar to
.td-module-meta-info {
height: 400px;
keeping author and READ MORE aligned at the bottom?
Unfortunately there are no settings for height of flex block, you can st it only using custom css -> https://i.imgur.com/e8dUVVd.png
.td_module_flex_1 .td-module-meta-info{
height: 400px
.td_module_flex_1 .td-module-meta-info .td-read-more{
position: absolute;
bottom: 10px;
The code will be apply on all flex block 1 so to make it to apply only on flex you want you can add an extra class -> https://i.imgur.com/wFv7l5V.png and the code will be
.my-class .td_module_flex_1 .td-module-meta-info{
height: 400px
.my-class .td_module_flex_1 .td-module-meta-info .td-read-more{
position: absolute;
bottom: 10px;
The code need to be set in theme panel> custom code> custom css.
Hope this will help you!
Thanks Calin! Sorry for the delay.
I am using the second version only where I need it, I have also applied the class to Posts Loop of the categories (applying the class to the Template), but I don’t see the same result that I get in Home where I have the simple Flex Block 1.
How can I also apply your CSS to the Posts Loop?
