Need to adjust the size of each of the 27 Boxes containing Articles on this Page to be identical. Which means the height likely needs to be adjusted. Can’t find a way to do so?
Here is the Page: https://www.bizcatalyst360.com/globalcast/
We are trying to edit all of the items listed under “START LISTENING NOW” SO each item is presented as the same size.
There are two ways to make the flex blocks on the same height, you can use tagDiv Composer on each flex block, or you can use a custom css to apply on all flex blocks -> http://prntscr.com/pm9r6e
.td_module_flex_1 .td-module-meta-info {
height: 170px;
Thank you, Calin. We’ve been trying to use tagDiv Composer on each flex block (instead of custom css) but can’t seem to find where/how to adjust the size of each block?
Hello !
The issue comes from the fact that your titles and descriptions on blocks are not the same. You will have to use the same ammount of text or use bigger blocks: https://www.screencast.com/t/Mqekumgi
Thank you for your understanding !
