Hi there!
I’m trying to list full numbers of articles in category page via set the post numbers in Tag Div Composer for that template. But have no luck to do this.
Rendering in browser shows that found only 3 posts, but there are more than 10 published.
block_tdi_73.td_column_number = “3”;
block_tdi_73.block_type = “td_flex_block_1”;
block_tdi_73.post_count = “3”;
block_tdi_73.found_posts = “3”;
block_tdi_73.header_color = “”;
block_tdi_73.ajax_pagination_infinite_stop = “”;
block_tdi_73.max_num_pages = “1”;
tdBlocksArray.push(block_tdi_73);
Here’s link
I think that I know what the problem is, please edit the cloud template with tagDiv Composer -> https://i.imgur.com/j8YvKks.png click on the block and remove the offset -> https://i.imgur.com/dJ0iFQu.png let that field empty.
Also, please check the limit posts -> https://i.imgur.com/8RH8pV3.png
