Flex Block 1: same height for elements?
Hi guys,
I’m working with the Tech Pro layout and try to customize the look and feel for my needs.
What I like to try: set the box heights in the Flex Block 1 Container (e.g. on the homepage) to the same size. Is there a standard option for this? I couldn’t find one… maybe I’ve missed it. Otherwhise I could try it with custom CSS. But first I would like to use the options of the theme.
Thank you for your help.
Best regards
Michael
For this you need to set the excerpt and title length on your locks and flex blocks from your homepage using tagDiv Composer like this -> https://i.imgur.com/l716eOr.png also the excerpt can be set on words or letters -> https://i.imgur.com/u9pwdUB.png -> https://forum.tagdiv.com/excerpts-introduction/
Hope this will help you!
