Flex Block 2 from GOSSIP demo home page – how to recreate (or how to save)?
I want to re-use the Flex Block from homage page of your GOSSIP demo on another template. The block where the meta is on white over the image in three columns, two rows.
When I save that as a custom block, the output is corrupted. This would be my 1st support question. Why is that?
I then tried to recreate it manually and I can never get the image to not extend outside of the column. This would be my 2nd support question. How?
Thirdly, as a general question: When importing a cloud template, do I always get all and any custom CSS in the front-end, or is there stuff hidden in files in the back-end?
Hello !
1;2 Please make sure that you don’t face any plugin conflicts. Those options should be saved automatically. Deactivate all the plugins except tagDiv Ones and let us know !
3. Yes, but please note that all the templates are Fully editable using tagDiv Composer and all the classes are dynamic so editing css raw would not work.
Alright, thank you for that. I now cannot recreate this error.
Would you please tell me, how is the image width on Flex Box 2 reduced to stay inside the column?
Hello !
As you can see here, the ROW layout that is there has been set to 4. Once that is changed you will be able to insert the flex block there and it will automatically adjust: https://www.screencast.com/t/5jCHudHQu You can see how to edit the ROW in our guide here: https://www.youtube.com/watch?v=fa7GenCHcBU&t=53s
Sadly, it does automatically adjust the image size for me.
How can I send you images that are not posted publicly?
Hello !
You will have to set more images. If you set only one the first image will become full row, you will have to add 2 or more images in order to have them smaller.
Set 2 images where?
Flex Box 2 does NOT automatically adjust the image size to the column size, no matter how many rows I add.
Hi andxtagdiv, if you like the flex block 2 from GOSSIP demo homepage, you can import that page from cloud template and you can edit it as you want or you can use the right click to save the Flex block 2 layout and use it where you like -> https://i.imgur.com/78TkEOq.png ->https://i.imgur.com/27x5Bod.png and you can edit it or you can use the right click on the elements that you want to save -> https://i.imgur.com/78TkEOq.png also if you want you can import block using this option -> https://i.imgur.com/tyFYelQ.png -> https://i.imgur.com/tyFYelQ.png
Also if you want to set here screenshots you need to store them on some platform and set here the link to it.
Hope this will help you!
I had the feeling that were past this, with the very good previous answers you gave. I do not have a “problem”, but I do want know how to achieve this setting.
As far as screen shots (and URLs) are concerned, sadly I cannot post any here because they are public and you do not delete them.
You still did not delete old ones that I had posted more than a year ago, although I did ask to do that multiple times.
If you want, we can continue this via email, there we’ll be privet and you can set the screenshots.
-> contact@tagdiv.com
Also I’m sorry for the old posts that was not deleted, let me know the one that you want to be deleted and the admin of forum will delete it.
Thank you for your understanding and sorry for inconvenience.
