I have been having some trouble getting the display for a particular block to look as I would like. I’m sure the support team is familiar enough with the layout options to offer a solution.
My home page is using Flex Block 4, which, by default, consists of two modules. In this screenshot, you’ll see how it displays:
https://postimg.cc/cKLshsgL
I would like this area to display all stories (six in total) as the stories in the green box. In other words, the stories in the blue box (Module 2) should display with an identical layout to the stories in the green box (Module 1). I don’t need two modules, just one module––Module 1––displaying six stories.
How can I do this?
Thanks for your help!
P.S. If the support team needs access to my WP site, credentials have been supplied via e-mail on the previous ticket under my account.
Then why not using the flex 1 -> https://www.screencast.com/t/wMxiSH6S3vu -> https://www.screencast.com/t/tabtpTwGx8kP this flex have all option to make the layout that you what to achieve.
Thank you for your understanding
