Flex Block and Post Loop
I’m trying to figure the best way to create a page that can select the category and able to use the normal numbered pagination altogether.
When I created a page using the Flex Block, I’m not able to have the normal numbered pagination. Can you please show me how I can have that option included in the block. If it need to edit the php file please let me know where I can edit the code.
Thank you
Hello !
For what you are looking to achieve it is recommended to use a Post loop element instead of a flex block.
The reason why I’m using flex block is because I can enable the unique id feature to eliminate the duplicate posts for page and able to choose the category filter.
Hello !
Unfortunately this option is not yet available in Newspaper Theme.
What other types of the block that I can use the numbered pagination beside the Post Loop?
Hello !
You can use Flex Blocks ( which we recommend due to their customizability options ).
As you can see here the pagination options can be found in tagDiv Composer: https://www.screencast.com/t/wb8jyXY8XW8
