Oct 31, 2023 at 9:14 am
I used for years for the pages, the Block 11, 15, 16, 18 because I only use the size 218 x 150
today i upgraded and those blocks are gone. I need to create from cloud tamplates from what i understand.
but everything is there 696 X 0; or is it also for 218 X 150 and I don’t see it?
Oct 31, 2023 at 9:37 am
Oct 31, 2023 at 12:51 pm
Thank you very much. I have one more question.
with it enabled Standard Pack if in the header ad disable display on mobile,
it’s like it’s not working. Ads appear normally on some pages.
sure now with what you’re showing me maybe i don’t need to have it enabled since i read that it also lags in loading.
Standard Pack except for DEFAULT SITE POST TEMPLATE it also has to do with Block 1, 2, 4.. if i understand correctly?
