Flex Block Builder problem
I am using the eco verse template, first time I have tried it but I get an error coming up
Flex Block BuilderThe Cloud Library Module Template set for this block is not valid or it no longer exists. Please select another Module Template.
Can anyone help please
Ensure you’ve set the module template in the flex block builder shortcode. Also, check that the module template you’ve set can be found in the Cloud Templates -> Modules. More info here: https://forum.tagdiv.com/flex-block-builder-flex-loop-builder/ -> https://forum.tagdiv.com/modules-builder-newspaper-theme/
