I’ve created 2 rows which include Flex Block 1 and Widget sidebar elements. I duplicated the row and it is displaying fine in the original row, however in the duplicate row the the articles in the Flex Block elements are displaying on 2 rows instead of 1.
Apologies I don’t know how to attached a scrnshot.
I do not quite understand the problem, please provide some more details and some screenshots , you duplicate the row like this -> https://www.screencast.com/t/FJaTW5sIpZL -> https://www.screencast.com/t/cX0LMLIrU5h
You can attach some screenshots with jing or directly on your website and provide the like to the screenshots.
Hi Calin,
The cause was that I was using a Smart sidebar instead of a standard sidebar widget. Once I switch to a standard sidebar widget the Flex Block started displaying fine again.
However I am still experiencing an issue when placing a Custom Ad block above content.
Screenshots:
https://snag.gy/dqJUfX.jpg
https://snag.gy/pk0CwZ.jpg
Just make sure that you are using flex blocks, those will adapt, also please use only one builder ( TagDiv Composer ).
If the problem persist, please provide some more details about blocks, row layout that you have set and is providing this problem, to can some investigations for this problem.
